How do I maintain image quality while converting PNG and TIFF into JPEG?
Sometimes, when I convert PNG or TIFF into JPEG, the quality drops a lot. Is there any method or software that allows me to control compression and maintain the original sharpness? I’d prefer a tool that lets me adjust quality levels.
When converting PNG and TIFF images into JPEG maintaining image quality depends on the right tool and settings. JPEG is a lossy format so a poor converter can reduce sharpness. I recommend using Softaken Image Converter Software because it allows you to convert PNG and TIFF files into JPEG without compromising much on quality. It supports bulk conversion, preserves original resolution and gives you control over output settings. To maintain clarity, choose a higher-quality output option during conversion. This way you can balance file size with visual quality. I’ve used it myself and the results are clean and professional.
