davidwilliams
When it comes to splitting a password-protected PST file, it depends on the tool you are using. If you utilize manual methods (such as Import/Export or moving data into various PST within Outlook) you must first input or remove the password as Outlook will not allow you to access or export the data without it.
However, with Softaken Split PST Tool, you are not required to erase the password before. The software is intended to handle password protected PST files (assuming you know the password). Simply enter the right password when requested and the application will split the file into smaller PSTs.
Some important details concerning the Softaken Split PST Tool
- Supports password-protected PST. You only need the correct password no need to remove it first.
- Multiple split options include size (e.g., 2GB, 5GB), year, folder and specified criteria.
- Maintains data integrity After splitting, attachments, metadata and folder structure stay intact.
- Compatibility Supports both ANSI and Unicode PST files from all Outlook versions.
