How it was easier for me to convert MBOX to PST Outlook
nickwatson2254
I nearly broke my head when I utterly had to migrate my MBOX email files into Outlook. I had tested several free tools, but either they didn’t work or my data got corrupted using them and nothing could I do. This is when I came across the WebbyAcad MBOX converter software.
This software has helped me primarily because I did not need any technical assistance to use it while importing my MBOX files and converting them to PST files. What amazed me most was the fact that all my emails, the attachments, as well as the folders that I used, which at some point was my main reason to use the app, were saved as is – nothing was deleted!
However, with the help of this batch conversion feature, I was able to save plenty of time to convert several files all at once. Besides that, the support team was nice and helpful in responding to any question I had, and the price was quite cheap to offer the service it offered.
I was pleased to find WebbyAcad with its wizards that helped me transfer the data from MBOX to Outlook directly the outcome is really good. I will recommend WebbyAcad MBOX to PST converter for anyone experiencing the same issue for converting MBOX files to PST file format that is supported by MS Outlook.
