Rebecca Gaither
As we all know, downloaded Spotify songs on Spotify app are only cached files and cannot be played on any unlicensed devices and players, including Audiomack.
With the above in mind, when it comes to converting tracks from Spotify to Audiomack, you need to make sure that your Spotify Music is an Audiomack compatible common audio file. On this condition, AudFree Spotify Music Converter can convert tracks from Spotify to MP3, WAV, M4A, AAC and other formats supported by Audiomack. Then, you can transfer and play Spotify Music on Audiomack without hassle.
After converting:
How to Sync Spotify Playlist to Audiomack
Step 1. First, log into your Audiomack account, or if you don't have one, register a new one.
Step 2. Once you have finished logging in, click on the 'Upload' button in the top right corner and select the upload type.
Step 3. Tap the "Upload a song" button in the middle of the screen, then browse for the music file on your computer and click "Open" to import the target Spotify Music file. Alternatively, you can simply use the drag and drop action to complete the song import.
Step 4. Now, you have successfully synced Spotify playlist to Audiomack, after that these Spotify Music will always be available on Audiomack.
After converting:
