Manual method PowerShell
To convert the Exchange EDB file to PST using the PowerShell command or Exchange Management shell user can simply follow these given steps:-
Step 1: Open the Exchange Management shell and put this given command line to get all mailboxes.
Get-MailboxStatistics -Database <NameofDatabase>
Step 2: After that just enter the given command to export the EDB file items to PST file format.
New-MailboxExportRequest -Mailbox <NameofMailbox> -FilePath \\ExchangeBackup\PST\MailboxName.PST
Step 3: The next step is to check the status of mailbox export request from this command.
Get-MailboxExportRequest
By using these tasks, you can user can freely export the single mailbox from the exchange database to PST.
Automatic solution
There are lots of automatic tools are available in the online market to make the conversion of EDB file to PST but here i recommend you the fastest and most effective software to export EDB file items to PST. I am talking about the eSoftTools EDB to PST Converter Software that speedily extracts all mailbox items from the corrupt Exchange EDB file and offers to save recovered items into a new Outlook PST file format within just a few minutes. This tool will simply allows users to make the recovery of Exchange mailboxes such as- emails, calendars, contacts, drafts, notes, tasks, etc. it is compatible with all version of MS Exchange Server including- 2003, 2007, 2010, 2013, 2016, and 2019.
Automatic solution
