How to Convert EML to OFT Format?
Anshu_123
In 2026, several tools are available to convert EML files, but if you are looking for the best and most reliable solution, then Cigati EML Converter is a good choice. This tool helps users convert EML files to OFT format quickly and securely without any data loss. It supports bulk conversion, so users can convert multiple EML files at once while preserving email properties like attachments, formatting, and metadata. Additionally, the software allows users to export EML files into multiple formats such as PST, MSG, MBOX, EMLX, PDF, and more. Moreover, this advanced utility is fully compatible with all major versions of the Windows Operating System.
