How to Convert Entourage to Outlook - Quick Guide
Anshu_123
If you need to convert Entourage to Outlook, keep in mind that Entourage data is stored in MBOX/identity files, which Outlook can’t import directly. Manual methods are complex and may result in missing emails or corrupted attachments.
For a smooth migration, you can use Cigati MBOX Converter. It helps convert Entourage mailboxes into Outlook PST format while preserving folder hierarchy, emails, and attachments. The tool also supports batch conversion and handles large mailboxes efficiently.
This is a simple and reliable way to move from Entourage to Outlook without data loss.
