Anshu_123
Calendar files in ICS (iCalendar) format are widely used by applications like Google Calendar, Outlook, and Apple Calendar. However, sometimes users need to convert ICS files into CSV format so they can easily open and manage the data in spreadsheet applications such as Microsoft Excel.
If you’re looking for a quick solution, this guide explains simple ways to convert an ICS file to CSV.
However, ICS files are not easy to analyze or edit in spreadsheet tools. That’s why many users convert them into CSV (Comma-Separated Values) format for easier access and reporting.
Limitation:
Manual methods can be time-consuming and may not preserve all event details, especially for large ICS files.
What is an ICS File?
An ICS file stores calendar data such as events, meeting details, reminders, and schedules. It is commonly used for sharing calendar information between different email and calendar platforms.However, ICS files are not easy to analyze or edit in spreadsheet tools. That’s why many users convert them into CSV (Comma-Separated Values) format for easier access and reporting.
Method 1: Convert ICS to CSV Manually (Using Calendar & Excel)
Follow these steps:- Import the ICS file into a calendar application like Outlook or Google Calendar.
- Open the calendar and locate the imported events.
- Export the calendar data into a supported format (usually CSV).
- Open the exported file in Microsoft Excel or any spreadsheet program.
- Save the file in CSV format if needed.
Method 2: Use a Professional Tool (Recommended)
For a faster and more accurate solution, you can use a professional converter such as Cigati ICS File Converter. This tool is designed to convert ICS files into multiple formats, including CSV, while maintaining the original calendar data.Steps to Convert ICS to CSV Using the Tool
- Install and launch the Cigati ICS File Converter.
- Click Add File or Add Folder to upload the ICS file.
- Preview the calendar events.
- Choose CSV as the output format.
- Select the destination path.
- Click Convert to export the file.
- Converts single or multiple ICS files at once
- Maintains event details such as date, time, and description
- Supports multiple output formats
- User-friendly interface for quick conversion
