How to Convert MBOX to EML while keeping attachments?
To convert MBOX to EML while keeping attachments, it’s important to use a method that preserves email integrity instead of manual extraction. A reliable way is to use the MailConverterTools MBOX Converter Tool, which is designed to keep all email components intact during conversion.
Start by installing and running the tool, then add your MBOX file or folder. The built-in preview option lets you check emails and their attachments before conversion. Next, select EML as the output format and make sure the option to exclude attachments is not enabled. Choose a destination folder and begin the conversion process.
Each email is saved as an individual EML file along with its original attachments, subject lines, sender details, and timestamps. This ensures that attachments remain linked to their respective emails and no data is lost during the MBOX to EML conversion.
There are two methods avaliable to export MBOX file to EML format. But i would like to explain about the professional because it do the all step automatically. You just need to add MBOX file in it and do a few click to export in EML format in proper folder structure.
Try MailsDaddy MBOX converter tool to open and import MBOX file into 8+ different file format including EML format. The software manages internal and external folder structure during the whole conversion process.
