How to Convert MBOX to EML with Attachments?
adviksoft
If you are looking for an easy and reliable way to convert MBOX to EML format, try using Advik MBOX to EML Converter. This smart tool helps you convert MBOX emails along with attachments into EML files without changing anything. It’s very simple to use and is perfect for both technical and non-technical users. You don’t need any other software to use it, and it works well on all versions of Windows.
