You can convert MBOX files to PST manually by First, installing Thunderbird and import your MBOX files, and then install the ImportExportTools NG extension and export emails as EML files. Then, import these EML files into Outlook and save them as a PST file. But the process is lengthy and does not preserve all email metadata or attachments.
To a best-in-class solution Use the DRS Softech MBOX to PST Converter. It has an end-to-end solution to convert MBOX to PST, PDF, EML, and 15+ others and direct export to top email platforms like Outlook, Gmail, Yahoo, and Office 365. It has support to strip multiple emails and also includes a free trial version (50 emails folder conversion). It is the ideal solution to migrate email with ease.
Easy Steps to Convert MBOX to PST:
1. Launch the MBOX File Converter tool
2. Import your MBOX file and choose emails to convert
3. Choose PST (or your desired format) as output
4. Choose a destination folder and click on Convert
Manual Method vs. BLR MBOX Converter Tool
The traditional method—installing Thunderbird, importing MBOX files, using the ImportExportTools NG extension, exporting as EML, and then importing into Outlook—is time-consuming, complex, and often results in lost attachments or metadata.
Why Choose the BLR MBOX Converter Tool?
  • Directly converts MBOX to PST, PDF, EML, MSG, HTML, and 15+ formats.
  • Exports directly to Outlook, Office 365, Gmail, Yahoo, etc.
  • Preserves all email attachments, structure, and metadata
  • Offers batch conversion with no size limit
  • User-friendly interface with advanced filters
  • Free trial available – convert up to 15 emails
Manually converting of MBOX file to PST is quiet complex and time consuming. It is possibility that some users can not apply this method. That is why, professionals recommend to use EmailsGuru MBOX to PST Converter. It is dedicated tool to convert single or multiple MBOX files to PST in a single process. The converted PST file can be easily access to any versions of Microsoft Outlook. Moreover, it has the capability to convert MBOX file of 25+ email applications like Yahoo Mail, Mozilla Thunderbird, Apple Mail, Netscape and many more. This tool smoothly works on any Windows platforms, offering a new users free demo version without buying.
