How to convert MBOX to PST files?
If you are troubled about How to convert MBOX to PST files. Then utilizing the third-party software and the best third-party tool is eSoftTools MBOX Converter. This tool has astonishing features like- email filters, free demo, bulk files conversion, support for all windows and outlook editions. It can give multiple migration options such as EML, EMLX, NSF, HTML, MSG, Office365, GMAIL, and YAHOO.
Get more info- Convert MBOX to PST files
You must try the most downloaded MBOX to PST Conversion Tool if you are searching for the best software. This perfect utility can easily convert all MBOX email files into PST file format which can be moved into multiple editions of the MS Outlook application including 2019.
The program offers direct and secure migration of MBOX emails into PST files with associated attachments. This software is perfect for those users who have no idea about this process as it contains all required options and sections with simple usability.
This software support all MAC OS & Windows OS. You can follow the steps of this amazing software through its demo version which can be downloaded for free.
facoc57
If you are looking for the Best MBOX to PST Converter, then using the most successful third-party tool that name is MBOX to Outlook Converter Suite. It can export MBOX to msg, EML, HTML, MHTML, and Office 365. The tool is completely tested by all online scanners. So it is safe and secure to use. It has a simple users interface that makes it easy to use for non-technical users. If you have any doubt regarding this software. Then you can attempt its free trial pack in which you can convert initial few items from each MBOX folder to pst or others formats in which users want to convert.
Open MBOX file with Outlook
Danish
MBOX to PST Converter is a smart tool to Convert Mbox files to PST formats. This tool gives you various unique features and efficient performance. It allows you to search automatically all mailbox files inside your computer and convert it to PST files within no time. Its advanced features can save files in various file formats and email clients.
Follow these steps to convert the MBOX files into PST file format manually:-
  1. Install MS Outlook and go to the File menu.
  2. NOW, select the Import & Export option to open the Import/Export Wizard.
  3. Click on the import from another program.
  4. Select Personal Folder File and tap on the Next button.
  5. Click the Browse option to save the resultant data.
  6. At last click on the Finish.
