How to Convert MBOX to PST files?
MBOX to PST Converter by eSoftTools is an excellent option. This software makes it easy to export convert MBOX file data to an Outlook PST file. MBOX to PST Converter restores CC, BCC, To, From, and attachments from email archives in a matter of seconds. It's also a simple and cheap and fast conversion. This app works in both MS Outlook and Windows versions. It also works with a variety of MBOX-based email clients.
For more info:- Convert MBOX to PST files
johnsheno
Search Google for SYSessential MBOX to PST Converter Software if you're seeking for a free MBOX to PST converter. This software provides a free trial pack that allows users to export up to 10 items from mbox to PST, EML, EMLX, MSG, and HTML files. It also works with all versions of Windows and Outlook. The software may convert MBOX files in bulk or individually.
The quickest way to convert MBOX files to PST is by using a tool like MBOX to PST Converter. It does not change the hierarchy of original folders and restore damaged or corrupted information. Also, the software is easy to use and conducts all mailbox items with all its attributes. A free demo version is also offered to all users you try it for making a free conversion of MBOX file with selective few items free of cost. The application is run in all versions of MBOX and Window OS systems and it doesn't require Outlook for MBOX to PST Conversion.
