1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How to convert MBOX to PST?
Discussion in 'OST-PST-MBOX-NSF-EDB-EML (Lotus/Outlook etc.)' started by Michael Rechard, Sep 20, 2017.
  1. Michael Rechard
    Michael Rechard New Member
    Convert MBOX to PST with the advance and simple MBOX converter software. This MBOX to PST Converter software scans the normal or corrupt MBOX files and perform the safe and complete conversion of MBOX file into PST, EML, MSG, RTF and HTML files format. This MBOX converter tool also support all popular email clients application like- Thunderbird, Pocomail, AppleMail, Entourage, Spicebird, Eudora, , MozillaMail, Incredimail, Opera Mail, Evolution, etc. and convert them into an Outlook PST format.
    To download this MBOX to PST converter software visit here: MBOX to PST Converter tool
    You may also read the article: Manual conversion of MBOX to PST to know the popular manual methods of MBOX to PST format.
  2. Kane Williamson
    Kane Williamson New Member
  3. Vernon Philander
    Vernon Philander New Member
    For an easy and instant solution to convert MBOX to PST (http://www.recoverfilesdownload.com/mbox-to-pst-converter.html) files, you should try to take a help of any perfect conversion application like Mbox to Pst Converter Software that can easily transfer or move MBOX files of different mail client to Outlook PST files.It provides you with a stop solution for successful conversion of MBOX files into Apple Mail, Entourage, Thunderbird or Power mail in Outlook PST file created importable perform.This is one of the best tools to export MBOX files into Outlook 2013, 2010, 2007, 2003 and all below versions.
    Further details visit us :-http://www.recoverfilesdownload.com/mbox-to-pst-converter.html
  4. barsewatson
    barsewatson New Member
    If you are facing any kinds of difficulty with migrate mbox file to pst format, then you can take help of MBOX to PST Converter tool to easiest way to migrate all mbox file cratered by email clients including Entourage, AppleMail, Postbox, Eudora, PocoMail, Netscape, Thunderbird, Opera, Spicebird, PowerMail, Claws Mail, Evolution, SeaMonkey, Sylpheed, Mulberry, GyazMail, Gnu, Sparrow and The Bat! User can get more information, visit from: http://www.mboxtopsts.com
  5. swewalker
    swewalker New Member
  6. benstokes
    benstokes New Member
    Hi,
    Are you looking to move your MBOX files to Outlook, then in that case users need to convert MBOX to PST file format to access the entire MBOX data in Outlook. It can be done by using the best tool MBOX to PST converter which easily export MBOX files to PST format in few moments. It can easily supports MBOX files of any MBOX supporting email client and convert it into PST format.
    For More Info: - https://gallery.technet.microsoft.com/MBOX-to-PST-Converter-8e762aeb
  7. Supriya Chakraworty
    Supriya Chakraworty New Member
    There are numerous option to convert MBOX to PST. If you are looking for a reliable, instant and best solution. Then you can easily import MBOX to PST by using a tool which is not only easy to perform. It has multiple features i.e, supports MBOX file to PST, EML, MSG, NSF, Office 365. Migrate Thunderbird to Outlook, import Eudora to Outlook, transfer Apple mail or Mozilla mail to Outlook. For more information click on http://download.cnet.com/SysTools-MBOX-Converter/3000-2369_4-76171902.html
  8. piter222
    piter222 New Member
    There are multiple third party application are available in the market, you can download from the internet. you just need to find right solution. I have used MBOX to PST Converter tool when i required same issue and got accurate result. So if you want to download this software please click here: MBOX to PST Converter
  9. Abrienne
    Abrienne New Member
    A suggested conversion Solution to convert MBOX to PST Format is using this MBOX Converter. This tool will assist you for a successful migration from MBOX file into Outlook PST file format; named as MBOX Converter or MBOX to PST Converter. With this automated solution, the user can easily convert unlimited file from MBOX to PST format. This software can convert multiple files at once via Batch conversion option.
    Visit know its more awesome feature http://www.convertmbox2pst.com/
  10. Christian Stewart
    Christian Stewart New Member
  11. Kieran Stephenson
    Kieran Stephenson New Member
    Before you can purchase any paid software for OLM to PST conversion, you should try an easy manual trick to transfer mailbox content from Apple Mail to Windows Outlook. If it fails or doesn't work, then only you should try a professional MBOX converter tool. The manual trick doesn't require any paid utility or any cost. You can freely use it for transferring email messages and other mailbox content from MBOX files of Apple Mail to Windows Outlook. Though the manual trick is lengthy but can give you effective results.
    You can read this blog post for detailed information: MBOX to PST Manual Conversion – An Easy Tutorial | N. Sem's Blog
  12. Jamie Kaler
    Jamie Kaler New Member
    If you have multiple MBOX files which you want to open in MS Outlook then opt for MBOX to PST converter. It allows you to create single PST file for each MBOX file keeping the folder structure intact. This tool is an easy to use wizard for MBOX to PST file conversion and help you open the MBOX file within MS Outlook.
  13. James Wold
    James Wold New Member
    Mail Passport Lite is the solution you re looking for to convert MBOX to PST. An easy to use advance migration solution to convert your mail database to desired PST file format for Outlook 2016 / 2013 / 2011 / 2010 / 2007 / 2003 & Office 365 for both Mac and Window. It is also a 2 in 1 email converter tool which also convert EML and MBOX file at the same time.
    For more details visit : mailpassportlite.com
Share This Page
