Well if you search about the simplest way to convert NSF to PST without data loss then you may find a lot of results. But the most important thing is to save data integrity. So, for this purpose you can try a secure application like Instant Data Care (IDC) NSF to PST Converter Software. This tool can automate the entire process without data loss. Also this tool can act as NSF file viewer even if it is damaged or encrypted. Simply follow the below steps to convert NSF to PST file easily:
- Download and install IDC NSF to PST Converter Software for free from the official website.
- Open the tool and select NSF file option to provide .nsf file to the tool.
- the complete mailbox will appear on the screen. Choose the items which are intended to be migrated. This may include e-mails, notes, calendars, contacts, tasks, journals, etc.
- Click on Convert option and a list of conversion options will appear including PST, MSG, EML, EMLX, HTML, MBOX, VCF, ICS and MBOX. Select PST and proceed by convert button. The conversion process will start after complete migration, you will be notified.
