How to Convert OFT to NSF Without Errors?
If you're trying to convert Outlook OFT files to Lotus Notes NSF, you’ve probably noticed there’s no built-in method. Outlook templates aren’t compatible with Notes, so manual methods often fail or break formatting.
A practical solution is using a dedicated OFT to NSF conversion tool. I recently used eSoftTools OFT Converter Software, and it handled the conversion smoothly. It keeps the original layout, attachments, metadata, and supports batch file processing—super helpful if you have multiple OFT files.
If you're migrating from Outlook to Lotus Notes, this method is simple and reliable.
