How to convert OST files to MBOX?
Go with eSoftTools OST to MBOX converter software that helps to convert OST files to MBOX without losing OST file data. It is easy to use because it comes with a user-friendly and graphical user interface that helps technical and non-technical users for operating the software without any effort. It converts single as well as multiple OST files to MBOX and other 10+ formats. It also converts emails of selected dates by date range. Want to know more about the software then you must use the free demo version in which users can convert 25 items from each folder of the OST file.
Read More: Convert OST files to MBOX
If you want to convert OST to MBOX you can use CloudMigration OST to PST Converter Tool. with this tool you can easily convert your OST file in multiple file formats and email clients. You can run this tool without any technical knowledge. its supports all windows version. Try its free demo version.
