How to Convert OST to PST files?
eSoftTools is a software development company its OST to PST Converter is a powerful tool for converting OST to PST files. This is a well-designed application that allows email migration from OST to PST a convenience. It quickly exports attachments, images, journals, contact lists, tasks, schedules, files, and notes from all email messages. MS Exchange Server and MS Outlook versions up to 2019 are supported by the software.
Read More:- Convert OST to PST files
If any OST client is unable to open an OST file in Outlook, then pcinfotools OST to PST Converter Software should be downloaded. This application can restore all damaged OST mailbox objects with meta attributes and works with all versions of MS Outlook. It also recovers emails, documents, journals, appointments, attachments, deleted files, chats, notes, tasks, etc without any error. Now you may get a free demo of everything that is offered. Read more :- https://www.pcinfotools.com/ost-to-pst-converter/
johnsheno
With SYSessential OST to PST Converter, you can convert Outlook data files from OST to PST in only a few clicks. This OST converter utility can recover data from corrupt OST files and convert it to EML, MSG, MBOX, EMLX, vCard, and vCal formats.
  1. How to Convert an OST File to a PST File
  2. Using the SYSessential OST Converter software, open the OST file.
  3. In the Convert option, select PST as the file type and the target folder.
  4. To save all Outlook mailbox data as a PST file, click Convert Now.
  5. To access all of your emails, contacts, calendar, and other information, import an exported PST file into Outlook.
