How to convert OST to PST files?
I recommend you to use try eSoftTools OST to PST Converter, an outstanding software for converting OST to PST without losing any single bit of data. It can convert OST to PST files and also quickly import them into EML, vCard, Office 365, EMLX, HTML, MSG, Yahoo, Gmail, and others. It can also support all Outlook and Windows editions.
Read More:- convert OST to PST files
mcnallyd
The method for converting OST addresses, contacts, attachments, and calendars to Outlook PST is SysInspire OST to PST Converter method. All OST data should be transferred to PST/ EML/ MBOX, CSV/ vCard/ MSG/ HTML, and OFFICE 365. To quickly recover from any type of error and migrate all of the data. Both versions of Windows and Outlook are supported by the app.
Read More:- Convert OST File to PST
SysOZ OST to PST Converter will export deleted OST data easily along with emails, inbox, sent the item, draft, delete-items, attachment, calendar, notes, task (To, Cc, Bcc, Date, From, Object and Time). You can try the free demo version of this software to convert up to 30 emails for free. You can also convert your data into various formats like PST, EML, EMLX, MSG, vCal, vCard, MBOX etc. The free demo version of this software displays the full process of this utility. This is the only tool which can finish your work in just few minutes.
