How to convert OST to PST files?
The eSoftTools OST to PST Converter is a popular tool for those who want to convert OST file to a PST file while keeping the email characteristics and folder structure. It allows users to convert and restore OST files, including attachments, to PST format. It is a multi-supported email program that can handle all versions of MS Outlook's OST file and import the resulting PST file directly. It is a Windows-compatible application that may be installed on any version of Windows, including Windows 10, 8.1, 8, 7, and all previous versions. Users may also try out the utility's demo version, which allows them to convert 25 items from an OST file to a PST file.
Read more:- Convert OST to PST files
OST to PST Converter is an instant solution to Convert OST data to PST file format. All items like such as contacts, calendars, emails, attachments, etc. are exported from OST file to PST file format. In a couple of clicks, OST mailboxes into PST format are exported by the software. Having an interactive interface, users will not face any trouble in understanding the software working.
Solve your OST file problem with the Exchange OST to PST Converter software. This tool is very simple and user friendly . Its easily convert OST file to PST and various file formats such as MSG, HTML, MBOX, EML, and EMLX. It's allows you to migrate an Exchange Database file to PST with attachments, emails, contacts, calendar, drafts, schedule, and etc. It's also give you money back guarantee and technical support. Download the free demo version of this software and get few mailbox items from each folder.
AnkitAryson
You can try MacSonik OST to PST Converter to convert your OST files into PST with attachments. It is the most reliable and perfect solution to convert single/multiple OST files into PST format. Users can remove duplicate emails from the conversion and migration process on the basis of To, From, Date, Subject, etc. OST to PST Converter for Mac also has a Mail Filter feature to convert and migrate selected emails only. Moreover, users can preview the files before the conversion process and set the custom folder name and the location of the resultant file.
The best and most effective tool for converting an OST file into an Outlook PST file with no data loss and perfect accuracy is called OST to PST Converter. It is the best software to convert OST files to PST files and other file types, including MBOX, PDF, and JSON. Additionally, the software can export OST items—emails, calendars, contacts, and tasks—into 15+ web- and cloud-based email applications.
