How to convert OST to PST without MS Outlook?
If you are confused regarding the conversion of OST to PST without installation, Use esoftTools OST to PST converter tool. This program converts the OST file into multiple formats like Office 365, MBOX, CSV, EML, MSG, and vCard, HTML, PST Outlook and it does not require installation of MS Outlook to convert OST to PST. It supports all file versions like 2000, 2003, 2007, 2010, 2013, 2016, 2019 and for the secure recovery, this tool shows the smart preview to the user. This program is free to download from the official website and simple to use, no technical knowledge is required to operate this tool efficiently. A FREE DEMO pack is also provided by eSoftTools, up to 25 emails can be converted into all format by this demo version.
OST to PST Converter is a great designed Software that transfer OST data to PST format. By this tool, the users can access inaccessible OST items such as emails, contacts, notes, journals, tasks, calendars, etc.-
* It works on OST file versions-2003, 2007, 2010, 2013, 2016. 2019.
* It works with all Windows OS version like: XP, Vista, 7, 8.1 and 10.
* Compatible with entire MS Outlook (32 and 64bits) version.
More info visit here;- https://www.datavare.com/software/ost-to-pst-converter-expert.html
Must Download and Install Ignissta OST to PST Converter software. This software helps to repair and recover damaged OST file and Convert OST to PST File format. By using Ignissta OST to PST converter software you can convert ost file to multiple file format like: EML, Office 365, Vcard, MSG and EML. Split Large OST file to small PST file option is also available and you can convert selected emails item by using Date Fillter.
Download Now https://www.ignissta.com/ost-to-pst-converter/
1464
ATS OST to PST Conversion application supportable with every version of Lotus Notes 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0. Using this software you can divide your large OST files into several small PST files according to your need. There is no size limitation to import the NSF data into PST data file. This application extract NSF data along with emails, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes into PST and another file formats such as EMLX, EML MBOX, MSG, HTML, CSV, vCard, vCal. Without installing MS Outlook in your system you can transfer your data from one format to another as per your need.
Read more: https://ats-ost-to-pst-converter-toolkit.en.softonic.com
Here is the best solution to convert OST to PST without ms Outlook with the help of eSoftTools OST to PST Converter Software.
Key features of OST to PST Conversion
  • No need MS Outlook application during conversion OST to PST
  • Recover all OST email properties like To, CC, BCC, Time, Date, Subject, Image, etc.
  • Import OST file format into multiple file formats such as PST, MBOX, EML, EMLX, MSG, Office365, HTML, vCard, VCF file
  • Complet mailbox conversion from OST like Convert OST email, Attachments, Contacts, Calendar, Journals, Notes, Task, etc.
  • Supports all MS Outlook versions up to 2019 and Windows versions up to 10 (32-bit, & 64-bit)
It gives FREE DEMO VERSIONS to recover OST file and save 50 items from each folder.
Get More Info:- OST Recovery Software
OST to PST software that is 100% safely repair damage Exchange OST mailbox data as well as gives the full authority to see the recovered the OST mailbox database without effective any originals emails data. It simply saves the converted mailbox data into PST, MSG, EML/EMLX, and HTML/MHTML file formats.
Read more: http://www.ost.backuptool.org/
eSoftTools OST to PST Converter to easily Export all internal items from OST files like emails, contacts, chats, tasks, notes, journals, and appointments to PST Outlook in a very short time. It provides the facility to recover all the database from corrupt and inaccessible OST file. by this free OST conversion tool the user gets the power to move the selective single and multiple items from OST file various readable file formats such as PST, EML, EMLX, MSG, HTML, vCard, VCF, MBOX, and also it supports to transfer OST to Office 365 Cloud.
Get More Info: OST Recovery
You have two methods to convert OST to PST using the manual and technical ways but in the manual, you can't convert OST to PST without MS Outlook so here I want to share the Softaken OST to PST Converter Software that enables users to convert OST to PST without MS Outlook. In addition, it restores all corrupted Outlook OST email contents, including drafts, notes, tasks, journals, and sent mail in addition to the inbox and outbox. It offers a simple graphic user interface so that users can use its features with less technical knowledge. You can convert your data in several file formats, including PST, EML, EMLX, MSG, VCF, ICS, MBOX, PDF, TGZ, HTML, NSF, and Office 365, once the recovery procedure is complete. You may quickly read the converted PST file on any version of Microsoft Outlook, including Outlook 2013, 2016, 2019, and 2021 versions.
