How to Convert OST to PST Without Outlook? Smart Solution
You can convert an OST file to PST without Outlook by eSoftTools OST to PST Converter Software to convert all items of an OST file without Outlook. This software makes it easy to upload an OST file which is instantly converted to PST file and your data remains safe. This software converts OST to PST files of two types: Your uploaded file gets converted as a single or bulk file/folder in seconds and you can download this software and send it to your email before conversion. Can send on. Can save tasks, events and contacts. Can manage filtration of calendars and other items.
Read more :- Convert OST to PST Without Outlook
Many excellent OST to PST converter tools are available. If you're looking for one of the best, consider ToolsBaer OST to PST Conversion Tool. It provides excellent results and can restore and convert damaged, corrupted, dismounted, oversized, inaccessible, and large OST files. This application has a user-friendly interface, making it easy for both professionals and individual users to use.
Read more: https://www.toolsbaer.com/ost-to-pst-conversion/
If users are looking for a solution for how to change the OST file into PST Outlook, then users have two approaches: a manual solution and a technological solution. Manual users must follow these procedures. Open Microsoft Outlook and go to File > Open and Export > Import/Export. Next: In the Import and Export Wizard, select Export to a file, then hit Next. Select Outlook Data File (.pst) as the file type and then click Next. Select which mailboxes and folders to export. If necessary, you can include subfolders and then specify a location to save the new PST file, however in this method, users can't process without Outlook and they can't perform without technical abilities, therefore I'd like to recommend MailVita OST to PST Converter Tool for Mac since it is the best and fastest way to convert ost to pst without Outlook, and users will not face any additional obstacles throughout the conversion. It is also compatible with Microsoft Outlook versions 2021, 2019, 2016, 2013, 2010, 2007, 2003, and 2000. You do not need any technological expertise to use this application. You can test the trial version to see whether it meets your needs. It is an easy-to-use utility. Users can download and install this application for free on both Mac and Windows. This tool is an excellent alternative for converting OST to PST without using MS Outlook.
