1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How to convert OST to PST?
Discussion in 'OST-PST-MBOX-NSF-EDB-EML (Lotus/Outlook etc.)' started by Michael Rechard, Sep 7, 2017.
  1. Michael Rechard
    Michael Rechard New Member
    OST to PST Converter software is the best option if you want to fast convert the normal or corrupt OST file into PST, MSG, DBX, EML, MBOX and Archive files format. This OST Recovery software comes with advance features which made easy for us to import OST file data like- email, task, calendar, contacts, distribution group etc. into an Outlook PST file format. This OST Recovery tool support all the MS Outlook versions and is compatible with Windows 10, 8, 7, Vista, 2003, XP and 2000.
    You can see more information at: OST to PST Converter software
  2. konkaebook
    konkaebook New Member
    Hello, Thanks for Perfect Data Solutions team for guide me free DEMO service after by PDS OST to PST Software that has available more facilities for recovery inaccessible emails of Offline OST file and also again read each most important data from OST to PST file with multiple formats. I also know about a PDS OST to PST converter software which can be used to fix & repair corrupted offline OST file data and conversion items from OST to Outlook PST format. This Software can smoothly transfer with shift emails-mailbox, inbox, contacts from OST file into new Outlook PST file with It also filter messages Completely.
    More Info-: OST Converter
    [​IMG]
  3. shivgupta
    shivgupta Member
    To easily convert OST mailbox data into an Outlook PST file, I would like to refer an excellent third party software, OST to PST converter. The software supports all versions of MS Exchange and Outlook, including 2016 & 2013. In addition, users can also convert multiple mailboxes from OST to PST in a single attempt. For more information about the software, visit- https://www.convertosttopstfree.org
  4. summerzoe
    summerzoe New Member
    I used OST to PST Software9.4 and you can try Free Demo version service of Microsoft OST to PST Converter software that recover corrupted OST file and Convert OST file to PST file with emails properties or mailbox attachments. This is great way for repairing file of Offline Outlook OST data as well as restore OST items into new Outlook PST file with -: MSG, EML, HTML, MBOX, and PDF formats. By using the OST to PST converter tool smoothly split recovered Outlook PST file into small PST file( 1GB to 5GB).
    More Info-: OST to PST Converter
  5. unitexmac
    unitexmac New Member
    If you are struggling to export OST to PST format, then here you got your tool that is resolves your problem after few clicks. The tool allows you to convert OST data into readable PST format in several situations such as server downtime, accidental account deletion, malware attack, crash of Outlook, and many more.
    For more info : https://borntolearn.mslearn.net/forums/f/560/t/330063
  6. romantrump
    romantrump New Member
    For converting ost file backup into outlook pst format ,first of all choose good and best kind of software like as this http://www.atomtechsoft.com/outlookosttopst.html and install software properly after that add ost file backup for recovery and export into pst .Follow steps and automatically your whole backup will restore and convert from ost to pst .
    [​IMG]
  7. swewalker
    swewalker New Member
  8. Puran
    Puran New Member
    here is another helpful way to Convert OST to PST
  9. summerzoe
    Convert OST to PST tool is best the recovery solutions for corrupted offline Outlook OST File to again open file items in readable way from OST to PST file. It is create way to repair damaged emails of OST file as well as quickly conversion emails,mails,contacts,index,properties or attachments from OST file into new Outlook formats such as-: PST,EML,MSG,HTML,MBOX and PDF formats. It provides filter messages option to filter emails from date to date and also present great option naming convention to restore emails by such as - subject + From + Date etc. This software works on all supported versions of MS Outlook ( 97 to 2016 ).
    More Info-: PDS OST to PST Converter software to Recover OST File & Conversion OST to PST
  10. Codie
    Codie New Member
    The OST to PST converter software enables data recovery from the corrupted OST files into outlook personal files. This recovery software is helpful in recovery and you have lost all hopes to recover information. It converts all types of corrupt files of MS office email clients. It can thoroughly scans the offline contents of OST file and converts the same into the PST file. This has interactive GUI feature which repairs the OST files and helps you to select the one you need to convert into PST file.The trial version is free of cost which enables you to know the features of the tool which helps you in perfect OST to PST Converter.
    For more information of this software: https://www.edbmails.com/pages/ost-to-pst-converter-for-ost-to-pst.html
    Have a look on this video:
  11. marsaljems
    marsaljems New Member
    In case your Outlook OST file got stuck or you want to convert OST file data information into PST file then you can use OST to PST Converter tool which will allow you not only conversion rather it will first repair unreadable OST file and once it repair it will recover all exchange data information even also meta data like Cc, Bcc, subject & attachment easily without putting any extra effort.
    Get more info: http://www.bulkecommerce.com/store/ats-ost-to-pst-converter-software-159.html
Share This Page
