How to convert OST to PST?
Are you looking for a OST to PST Converter to convert OST to PST? You can try eSoftTools OST to PST Converter Software to migrate the OST database file to Outlook PST file format that has superb features. This tool can convert multiple mailboxes which contains inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time). The utility not create any changes in the information of the database. The software switches OST files into innumerable file formats such as PST, EML, MSG, MBOX, HTML, and VCF file formats. It support all MS Outlook version like 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016, 2019 (32bit & 64bit).
For more information visit here:- Convert OST to PST
Get the quick and error-free solution to import OST to PST format, Try OST to PST Converter to export single or batch of OST files to PST format with an attachment. The user-friendly GUI of this tool makes it comfortable for non-technical users. This tool maintains the folder structure of OST files during conversion from OST to PST format. It is fully supportable to OST and all the versions of Microsft Outlook.
Visit at : https://www.osttopstapp.com/
