How to convert ost to pst
camilia
if you need best conversion tool which easily convert OST to PST Outlook, so you can instantly try master third-party tool of KDETools OST to PST converter software. The migration tool can easily convert bulk OST file/folder into PST outlook format and also save email residences, including attachments, tasks, notes, journals, calendars, zip attachments, and embedded photos. In addition to some emails. Along with you can also transfer individual emails to different formats by helping all MS Outlook versions 2019, 2016, 2013, 2010, 2007, etc. The application offers multiple platforms for the migration of OST database files like- PST, EML, Zimbra, Gmail, Office 365, Live Exchange Server, EMLX, MBOX, MSG, vCal, vCard, HTML, NSF, PDF and etc.
And to export the OST mailboxes to PST, follow the simple procedure:
1. Go to Files >Open & Export and click Import & Export.
2. Select Export to a file; then click Next.
3. Select the second option—Outlook Data File.
4. Select the folder which you want to export and click Next.
More info- Convert OST to PST
OST to PST Conversion process is very simple to perform and achieve successfully by using the OST to PST tool that can automatically convert your OST files to PST files. It can recover all corrupted OST file to PST Outlook data without any issues facing. It supports all MS Outlook version like:- 2003, 2007, 2010, 2013, 2016, 2019 etc.
Cigatisol
If you are searching for the most reliable and trusted OST to PST Converter, then you can download our professional Cigati OST File Converter Tool. It provides the fastest and safest OST Conversion into Outlook PST with all the attachments file. The utility software allows the users to securely convert the normal as well as corrupt OST files into PST format without any data loss.
ruchika
1. Browse OST file ----------------> 2. Preview MAils Items----------------------------> 3. Export to PST File
