Rebecca Gaither
You'd better use AudFree Spotify Music Converter to convert Spotify Music to MP3, WAV, M4A, AAC and other formats supported by Audiomack. Then, you can transfer and play Spotify Music on Audiomack without hassle.
AudFree SpoDable has an intuitive and simple user interface that you can get started quickly, whether you're a Spotify premium or free user. In terms of conversion speed, it can download and convert any Spotify song of your preference at up to 5X speed without any loss of quality.
How to Sync Spotify Playlist to Audiomack
Step 1. First, log into your Audiomack account, or if you don't have one, register a new one.
Step 2. Once you have finished logging in, click on the 'Upload' button in the top right corner and select the upload type.
Step 3. Tap the "Upload a song" button in the middle of the screen, then browse for the music file on your computer and click "Open" to import the target Spotify Music file. Alternatively, you can simply use the drag and drop action to complete the song import.
Step 4. Now, you have successfully synced Spotify playlist to Audiomack, after that these Spotify Music will always be available on Audiomack.
