How to Convert Spreadsheet Contacts into vCard/VCF format/
Spreadsheets are frequently used to maintain contact information because of their organized nature and ease of usage. However, when it comes to sharing or syncing contacts between platforms and devices, the vCard (.vcf) format is the most commonly utilized. As a result, most of the user want to convert their spreadsheet contacts into vCard/VCF format. Some users can convert their Excel spreadsheet contacts into vCard or VCF format manually but this method is associated with lots of drawbacks and also this method fails when you have a batch of data. So rather than using hard and risky ways, users can use a trusted and effective program like Softaken Excel to vCard Converter Software. With the help of this program, users can easily convert their batch of spreadsheet contacts into vCard or VCF format in just a few simple and easy steps. Also, this advanced software runs smoothly with all editions of Microsoft Windows. For more information, you install the trial version of this utility for free.
If you want to convert addresses from Excel to VCF, you can use the ToolsBaer Address Book Converter software, which is a third-party solution for that. Using this you can quickly convert Excel files to Vcards. Excel to vCard Conversion supports both Excel and VCF versions. It also provides a live preview of all Excel files. This function allows users to easily convert single Excel transactions and multiple Excel transactions to Vcard transactions. To try it out and see if it works for you, download the free trial and contact the technical support team.
How to convert contacts from Excel to Outlook?
  • Download the ToolsBaer Address Book Converter Tool and install it on your PC.
  • Then select the option from the option provided - "Export to VCF".
  • Use the Browse tab to add Excel files.
  • Decide where to store the created VCF file.
  • Press the "Convert Now" button to begin the conversion process.
