How to convert VCF to Excel?
Anshu_123
Are you finding the best and easiest solution to convert VCF to Excel? Use the MacSonik vCard to CSV Converter that easily converts VCF into Excel. The software is designed in such a way that both professional and novice users can effortlessly convert vCard to CSV. It supports all vCard versions such as vCard v4.0, vCard v3.0, and so on. The software gives you 100% accuracy and also maintains data integrity. Moreover, you can export VCF to multiple file formats such as Outlook CSV, google CSV, Yahoo CSV, and iCloud CSV. Besides, you can also move it into PST file format.
