How To Easy Remove/Unlock iCloud Activation Lock
iremover
How to Remove & Bypass iCloud Lock? Many users are searching for a working way to bypass & remove iCloud Account Activation Lock on iPhone X,XS,8,7,6S, 6, 6 Plus, 5S, 5C, 5, 4S and iPad. The good news is that a new software is now available from iRemover. Since the iPhone is a very popular device, the iCloud Activation Lock is a common problem that most users have. It can happen to anyone due to many different reasons. For example, there are many users who may have this problem (with the activation lock feature) simply because they bought a used iPhone device either online or from a second hand retailer. Normally the seller is required to provide the Apple ID and password along with the device, but unfortunately in many situations this is not the case. If you ever decide to buy a used iPhone don't forget to ask for the Apple login credentials.
iRemover.org is a company that allow users to turn off/disable and bypass the iCloud activation lock. This new software works not only on all iPhone models but also on iPads as well.
onyiersan
If you need to remove iCloud lock if you forget the password, you can use an iCloud activation lock removal tool to remove the iCloud activation lock in one click. I have ever use a iPhone unlocking tool, it named UkeySoft Unlocker, which is a iPhone passcode unlock tool and Apple ID unlock tool, it not only can remove iPhone/iPad screen passcode within minutes, but also can remove iCloud activation lock on iPhone 11/XS/XR/X/9/8/7/6S/6/5S/5 and iPad & iPod touch.
Actually, after removing Apple ID, iCloud activation lock be removel at the same time.
Here is the guide on how to remove Apple ID from iPhone without password
Kevinhaloo
Thanks for sharing, iCloud activation lock is really difficult to handle. If you forget your password or don’t know the password, you really need some useful ways to bypass the iCloud activation lock.
Davaincoal
For iCloud activation lock, it's better to find out the original Apple ID and password to bypass the activation lock. The iCloud activation lock removal is the last choice when you forgot Apple id and password, locked out of idevice without apple id and password, try EelPhone Activation Lock Removal, which works on almost all iOS version.
