1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
How to erase messages from iPhone before selling?
Discussion in 'Smartphone Product Support' started by Perterdavily, Apr 9, 2016.
  1. Wasserty
    Wasserty New Member
    Well,in my opinion. how to erae everything is really difficult ,but the erased data are easy recovered , so . how to avoid this problem happen , maybe , we can only depth to delete data on iPhone for erase them
  2. Incidiya
    Incidiya New Member
    For iPhone, you can use FoneDog - iOS Data Eraser:
    • Easy and Simple, it is just click-through process.
    • You can erase full data or select priavte data you want to erase.
    • Permanently erase your private data, and absolutely unrecoverable.
    • No one can ever recover or view the erased data.
  3. Incidiya
    Incidiya New Member
  4. opar2016
    opar2016 New Member
    You can select the messages, and then choose erase. Another way is reset iPhone to factory settings.
  5. Edom
    Edom New Member
  6. Edom
    Edom New Member
    You can use FoneDog - iOS Data Eraser: There are many features and it is easy to use.
    • You can erase full data or select private data you want to erase.
  7. stephanic
    stephanic New Member
    Hi,
    It becomes very important when you want to sell you iPhone or to done it. Your data can be accessed by other person and also can be used for illegal purpose. So its better to delete every data permanently from your device. For that you should use some professional eraser tool because manually removal of data will not wipe your data permanently. So better to go for iPhone Data Eraser. This is one of the best software that wipe out every data from your device without any option left to restore it.
  8. kou
    kou New Member
    Apple offers solutions to erase iPhone data by using its Factory Settings feature. You can do that first, and than you need to save some useless data so that your old iPhone data can be completely covered by those data.
  9. kou
    kou New Member
  10. kou
    kou New Member
    If you want to know how to permanently delete iMessages, SMS, MMS and other messages, you can try this app - iOS Data Eraser. This data eraser tool will help you to completely and perfectly wipe iPhone for resale, including remover your sensitive messages and private data.
  11. Keitha Meyerson
    Keitha Meyerson New Member
    Before selling your iPhone, I think the first thing you should do is to delete everything on iPhone 5/6/7 to prevent the data leakage. Besides, through the normal way, your data will easily be recovered by most iPhone Data Recovery Software because the data still exist on somewhere in the memory after you delete them directly on your iPhone, so here you may refer to this article to know how to completely wipe an iPhone before selling or erase iPhone without any recovery possibility.
  12. Linae
    Linae New Member
    Hello there! You can easily do that by resetting your phone to factory setting. That way, all your data will be deleted including your messages. Make sure you have your backup :)
  13. Linae
    Linae New Member
Share This Page
