darlendson
You need a good audio converter that can handle high-bitrate encoding and keeps the original sound quality if you want to export audio files to AAC format without losing quality. With a good converter like Softaken Audio Video Converter, you can simply export audio files to AAC format without losing any quality. To keep the original sound quality, always use the right parameters and don't use low-bitrate conversion. Users can easily operate this application to export audio files to AAC format without losing the audio quality.
A Guide with Steps
Why use AAC?
A Guide with Steps
- Pick a Professional Audio Converter Tool: Use a reliable product like Softaken Audio Video Converter, which can convert audio without losing quality and works with the AAC format.
- Set up and start the software: Get the converter and set it up. Start the program on your computer.
- Bring in your audio files: To add source audio files (such MP3, WAV, or FLAC) to the converter, click "Add File(s)" or "Browse."
- Choose AAC as the output format.: Choose AAC from the list of output formats. Make sure the tool lets you change the output settings.
- Change the Audio Settings Bitrate: For better quality, set a higher bitrate (for example, 256 kbps or more). Sample Rate: Make sure it matches the original file, which is normally 44.1 kHz or 48 kHz.
- Pick the output destination: Choose the folder where you wish the converted AAC files to go.
- Start the change: To start exporting, click "Convert" or "Start." The process is fast and keeps the audio quality the same.
Why use AAC?
- At the same bitrate, it sounds better than MP3.
- Great for streaming and on-the-go devices
- Supported by a lot of platforms, including Apple, Android, and YouTube.
