You can effortlessly extract calendar from OST file using the Xtraxtor tool in just a few clicks. Its intuitive and user-friendly interface ensures a smooth and straightforward process for exporting calendar data from an OST file to a file on your system. Most importantly, the tool guarantees that no data will be lost during the extraction of your OST calendar events. Additionally, it allows you to save the calendar data in the widely supported ICS format, ensuring compatibility with other applications.
			Steps to Export OST Calendar to ICS File:
- Launch the Xtraxtor OST Converter tool.
- Add the desired OST file.
- Click on Export and select ICS as the output format.
- Browse to your target location and click the Save button.
