How to Export Zimbra to Outlook
camilia
Look for a reliable solution to export Zimbra to Outlook. Then you can try a commercial solution like KDETools Zimbra to Outlook Converter. The tool has many advanced features such as:
• With Zimbra Converter, the user can export Zimbra into Outlook PST and various types of file formats such as EML, EMLX, HTML, PDF, NSF, OLM, etc.
• The tool supports email servers such as Office 365 and Exchange Server accounts.
• The software displays a free preview option that you can use to compare the email with the attachment.
• The application is also compatible with all the latest Windows versions such as Windows 10, 8, 7, 2000, Vista, etc.
More info: http://www.zimbra-converter.com/info/free-zimbra-converter-to-export-zimbra-to-pst.html
You can easily convert TGZ to PST using an easy tool like TGZ to PST Converter. The application directly converts TGZ file to PST and multiple file formats such as MBOX, EML, EMLX, HTML, PDF, NSF, MSG, and, etc. The application maintains TGZ items such as emails, contacts, calendar, notes, attachment, tasks, journals, folder and etc. The application safely converts TGZ mail to PST without any data loss. The application also supports all the latest versions of Windows.
