Manoj Sharma
If a query returns an error saying it can’t find the table you’re trying to work with, it’s often because the table really doesn’t exist in that database instance. In MySQL, this shows up as error 1146, and it usually means your SQL is pointing to the wrong name or schema. One simple way to fix it is to run a SHOW TABLES command to list the tables in your database and make sure the one you need is listed. Another common situation is when migrations or restores don’t bring over all tables correctly. In those cases, restoring from an earlier backup or using a recovery tool can help bring missing data back.
