If you have a corrupted MBOX file and want to repair it, then you can use the Advik MBOX Repair Tool for that. The software will effortlessly repair your corrupted MBOX file and create a new healthy MBOX file. Additionally, you can also repair multiple MBOX files at once without affecting your data.
Steps to Repair Corrupted MBOX File With No Data Loss
1. Run the Advik MBOX Repair tool.
2. Add the MBOX files.
3. Select MBOX from the different saving options.
4. Browse the targeted location and hit the Convert button.
Done! Here you repair the corrupted MBOX file without affecting your data.
