Manoj Sharma
If Outlook keeps On Crashing, it can be due to corrupt PST files, faulty add-ins, or outdated software. To resolve this manually, start by launching Outlook in Safe Mode (Outlook.exe /safe) to check if add-ins are causing the issue. Disable unnecessary add-ins via File > Options > Add-ins > Manage COM Add-ins. Next, repair corrupt PST files using the Cigati Outlook PST Repair Tool, located in the Outlook installation folder. Run it, select your PST file, and repair errors. Additionally, update Outlook to the latest version through File > Office Account > Update Options, and create a new Outlook profile if the issue persists. However, manual methods can be time-consuming, may not fix severe corruption, and risk data loss.
To simplify the process, using the Cigati Outlook PST Repair Tool is a better alternative. This tool can repair highly corrupted PST files without size limitations, recover emails, contacts, calendars, and even restore deleted items effortlessly. It also ensures data integrity and allows saving repaired files in multiple formats. With its user-friendly interface, even non-technical users can resolve Outlook crashes efficiently, making it a reliable solution for PST file corruption and Outlook stability issues.
