How to Fix Outlook Receiving Emails but not Sending.
If Outlook Receiving Emails but not Sending them, the issue may be due to incorrect SMTP settings, a blocked port, corrupted Outlook profile, or PST file corruption. To fix this manually, first, check your SMTP settings by navigating to File > Account Settings > Email > Change and ensuring the correct outgoing server settings. Next, verify if port 587 with TLS encryption is enabled. If the issue persists, disable any antivirus or firewall that may be blocking emails. You can also repair the Outlook profile by going to Control Panel > Mail > Show Profiles and creating a new one. Additionally, clearing the Outbox folder and running Outlook in Safe Mode may resolve conflicts. However, if the PST file is corrupted, these steps may not work.
A simpler solution is using the Cigati Outlook PST Repair Tool, which efficiently repairs corrupted PST files and restores complete mailbox data, ensuring seamless email sending. The tool also resolves other Outlook issues by recovering missing or damaged emails without data loss. It supports all Outlook versions and provides a user-friendly interface for quick fixes. Using this tool eliminates the challenges of manual troubleshooting, ensuring smooth email communication.
