Ahana Singh
The Recovery Pending State in SQL Server is one of the common issues which most SQL users encounter. Such problems happen when the size of the database is full, thus if they keep happening, you should verify the size of the MDF file. The SQL becomes inoperable, making it unable to execute the new commands on the tables. Such a situation is very comparable to a database going into offline mode.
What are the main causes of the Recovery In Progress State?
You can fix this issue efficiently by following this informative technical guide. Here, you will manual steps and a professional tool to fix the recovery pending state in SQL Server.
- Full database partition or insufficient RAM
- Equipment failure
- A problem with the log files
- Due to any unfinished business or while
