smithjones24
You can import OST to iCloud manually or professionally. For manual, first convert the OST file into PST format via Outlook. Next, set up your iCloud account in Outlook via the iCloud add-in. Import the PST file to Outlook and transfer the emails from the PST folders to your iCloud mailbox folders.
This process needs Outlook and the iCloud add-in, which might not sync every time. It doesn't provide a direct import facility from OST to iCloud and can lead to loss of data or formatting while transferring.
To import an OST file into iCloud, always use a professional MigrateEmails OST to PST Converter Tool. This tool ensures 100% conversion of data with zero loss of data during importing. Furthermore, the software converts data to different output formats which can be supported by a variety of email applications, such as iCloud Mail. The converter tool provides enhanced data security throughout the conversion and import process. Furthermore, it assures 100% data transfer without any downtime or disruption in performance. In addition, the easy interface makes it easy for technical and non-technical users to utilize it. The utility supports a variety of Windows and macOS versions, facilitating extensive compatibility on different systems.
Upload Outlook OST files to iCloud Using the Tool
1. Download and install the MigrateEmaisl OST to PST Converter Tool on your system.
2. Then, navigate your system and choose the OST file that you need to convert.
3. Then, view mailbox data preview and select specific items for export.
4. In the list of supported email clients, choose iCloud as the output format.
5. Next, sign in using your administrator account details.
6. Here, implement any required filters or custom settings as desired.
7. Subsequently, click the Convert button to start and finalize the process.
