georgiajohnston
Importing Thunderbird to Outlook is easy with a professional and trusted tool, the BLR MBOX Converter Software offers reliable and smooth conversion. It allows a user to convert files in batch and large-size files at once without limitations. The software supports over 30+ formats (PST, PDF, CSV, EML, HTML, etc) and is compatible with several email clients. Allowing users to use software advanced features that simplify the user conversion process. The dashboard of the tool is simple and user-friendly, even a non-technical user can use it with ease along with just a few steps to export Thunderbird emails to Outlook.
Only 3 steps are needed to convert the files:
1. Import the files.
2. choose the format
3. save the files.
Additional pro step is users can select the other features to simplify the conversion.
Try the trial version:
Users can try the trial demo for free up to 15 emails by downloading it at once.
3. save the files.
