I installed Eraser on my USB flash drive and want to use it on various computers.
Unfortunately if I start Eraser on other computers it is not included in WinExplorer context menu.
Even if I go to erasers "Settings", then disable the checkbox "Intergrate Eraser into Windows Explorer", Save Settings, and re-enable it afterwards it is NOT added to the context menu.
So is there really no dynamic on/off integration of Eraser into WinExplorer?
This is possible as many other programs like famous 7zip archiver show.
They offer a dynamic on/off integration.
Could you add this to Eraser as well?
Thank you
Peter
Thank you
Peter
