anamikapandeyyy
To recover data from SD card manually, you can start by checking the Recycle Bin for deleted files. If they’re not there, you can use the "chkdsk" command in the Command Prompt to repair any file system issues. However, manual methods may not work effectively for severely corrupted or formatted SD cards.
For a more reliable solution, BLR data recovery software is an excellent choice. It thoroughly scans your SD card to recover lost, deleted, or formatted files with high accuracy. The software is easy to use and ensures a smooth recovery process, even for difficult cases where manual methods fall short.
