graceyin2017
If your iPhone is water damaged by accident and you can't use it as normal, don't be lost in panic. The first thing you should do is save your iPhone data. You can recover your important iPhone data before you find a way to fix your phone.
To recover data from water damaged iPhone X/8/7/6/5, you can refer to this article:
Retrieve Data from Water Damaged iPhone
Hope it helps!
Hope it helps!
