Iris Cheng
The loss of contacts is one of the problems that most Android users often encounter. There are many reasons for the loss of contacts, such as factory resetting restoration, device rooting, system upgrade failure, virus attacks, software crashes, and so on. However, the main reason is human error, that is, accidental deletion. In this case, how do you recover deleted contacts from Android? Don’t fret, here are 2 solutions for you!
Option 1. Restore Deleted Contacts from Android with Google Account
If you have previously synced your contacts with Google Account, when they are lost or deleted any day, you can restore them to their former appearance on your phone within the past 30 days. Here is how to do:
Option 2. Recover Deleted Contacts from Android without Backup
If you have never backed up before, you can recover deleted Android contacts via Gihosoft Android Data Recovery Software, which is powerful Android data recovery software with accurate algorithms and user-friendly interface. Whether your contacts or other Android files are lost for any reason, it can help you quickly retrieve them without backup file. Meanwhile, this software supports a variety of Android phones and tablets, for instance, Samsung, Huawei, LG, HTC, Motorola, Google, OnePlus, Sony, Lenovo, ZTE and so on.
- Open Google Contacts in your browser and sign in with your Google Account.
- Click “More > Restore Contacts” from the above menu, then select the appropriate time and tap “Restore” to recover deleted contacts on Android.
