How to Recover Deleted Files from a USB Flash/Pen Drive in 2025
To recover deleted files from a USB flash/pen drive in 2025, you can use BLR Pen Drive Data Recovery Software. This tool is designed to recover hidden lost data, formatted, or permanently deleted data from USB drives with ease. Whether you have accidentally deleted files, formatted your pen drive, or lost data due to corruption, this software can quickly scan your drive and retrieve your files. Simply connect your USB flash drive, launch the software, perform a deep scan, and recover your important data in just a few clicks. BLR Pen Drive Data Recovery Software ensures a high recovery success rate, making it ideal for recovering lost photos, videos, documents, and other important files.
Here are the steps to Recover Deleted Files from a USB Flash/Pen Drive using BLR Pen Drive Data Recovery Software:
  • Download and Install BLR Pen drive data recovery software on your system.
  • Connect your USB Flash/Pen Drive to the computer.
  • Launch the software and select the connected USB drive from the list of available drives.
  • Click on the "Scan" button to start scanning for deleted, hidden, or lost files.
  • Once the scan is complete, preview the recoverable files to verify your data.
  • Select the files you want to recover and click on the "Recover" button.
  • Choose a safe location on your system to save the recovered files (avoid saving them back to the USB drive).
  • Wait for the recovery process to complete and access your restored files easily.
If data isn't overwritten, it can typically still be recovered. Softaken Windows Data Recovery Software is a good choice because it can get files back from USB drives, SD cards, HDDs and SSDs. It can help you recover data that was erased by mistake, formatted disks, or RAW drives. You can even see files before restoring them. The application is easy to use, searches thoroughly for lost files and works even if the drive looks empty.
