How to Recover Hidden Lost Data From Pen Drive?
To recover hidden lost data from a pen drive manually, you can use the Command Prompt. Open CMD and type attrib -h -r -s /s /d X:\*.* (replace X with your pen drive letter) to unhide files. However, this method may not work for permanently lost data. For a more reliable solution, use BLR Pen drive data recovery software, which efficiently scans and restores hidden, deleted, or lost files from your pen drive, ensuring complete data recovery without complications.
Here are the steps to use BLR Pen Drive Data Recovery Software:
  1. Download & Install – Install BLR Pen Drive Data Recovery Software on your system.
  2. Connect the Pen Drive – Insert the affected pen drive into your computer.
  3. Launch the Software – Open the tool and select the connected pen drive.
  4. Scan for Lost Data – Choose Quick Scan or Deep Scan to search for lost files.
  5. Preview Recoverable Files – View the scanned results and select the files you want to recover.
  6. Recover & Save – Click on Recover, choose a safe location on your system, and save the recovered data.
This process ensures seamless recovery of hidden, deleted, or lost files from your pen drive.
