How to Restore Lost Data from Samsung Galaxy Note 8?
Tmzmo623
Samsung Note 8 will be equipped with Qualcomm Snapdragon 835 processor, and officially launched in August. But this does not mean that Samsung will not use some of its models in Note 8 its own Exynos chip, in fact, it was previously on the S8 phone so dry.
In fact, this may also be an immature product, Samsung has done a similar thing before. Earlier this year, Samsung had inadvertently divulged the Galaxy S8+ and Bixby product names in advance.
However, even though Samsung Note 8 performance is strong enough, but still can not avoid the situation of data loss, especially the photos. So, how to recover the lost data on Samsung Note 8 without backup? Please don't worry, you just need the Samsung Data Recovery.
Samsung Data Recovery is the outstanding data recovery program that allows you Directly to Recover Deleted Text Messages, Contacts, Videos, Photos, Call logs, Whatsapp Messages and other Document Files from Any Samsung Galaxy Phone and SD card.
Related: Transfer Samsung Data to Samsung Note 8
If you want to recover your precious data from Samsung mobile, I know an effective way that can solve this problem. Samsung Data Recovery program is the best choice for you to restore lost data from samsung galaxy mobile.
No only recover data from Samsung, it is also compatible with any Android operational system as well as newer devices, such as: Samsung, HTC, LG, Sony, Motorola, Huawei, Nexus and more.
how to restore lost audios from samsung galaxy
Gihosoft Free Android Data Recovery is a powerful Samsung data recovery app. With it, users can recover deleted or lost contacts, call logs, messages, photos, videos, audios, WhatsApp and Viber chat history, etc., from Samsung Galaxy Note 9, Samsung Galaxy S9/S9+, Samsung Galaxy S8/S8+ as well as other Android phones quickly. What’s more, this Samsung data recovery tool is highly reliable and extremely easy to use. You can view the step-by-step guide below to learn how to use this program to recover deleted data from your Samsung Galaxy phone.
  1. Download and install this free Android data recovery on your PC/Mac.
  2. Launch it, then select file types from the main interface and tap “Next”.
  3. Enable USB debugging on your phone first and connect it to the computer via a USB cable.
  4. Tap “OK” or “Allow” to authorize the connection on your phone screen when prompts.
  5. Once connected, click “Start” to scan the lost files from Samsung Galaxy phone.
  6. After the scanning process is over, you can preview all recoverable files that you’ve deleted.
  7. Check out any data you want, tap “Recover” to restore deleted data from Samsung.
Also Read: How to Remove FRP Lock from Samsung via Samsung FRP Helper 0.2
