If you are suffering from any problem regarding the Exchange EDB file and need to restore-mailbox exchange 2010 so you should try this eSoftTools EDB to PST converter software.
This software can convert EDB files into PST by the following steps:-
1. First, select the EDB file you want to repair and convert into a PST Outlook format.
2. It scans the file and removes the errors and shows the preview of Mailbox folders/sub-folders while recovering. 3.Shows the Formats that you want to convert your EDB files it provides 5 formats(HTML, PST, MSG, EML, and EMLX).
4. It supports all versions of Exchange servers and Outlook
Read More Info:-eSoftTools EDB to PST Converter software
