How to run Eraser with LOW priority ?
psto
I am missing an option which let me run Heidi Eraser with LOW priority.
Whenever I run Eraser for a large file (>500MB) or directory tree then it consumes a lot of CPU load.
This in turn affects other running programs.
Can I somehow lower the priority ?
Other programs offer an option for such purposes.
Control >shift>excape to get the task manager and then view the processes tab.
Find eraser.exe and rightclick on it and go to "set priority".. it should be on normal by default... but set it where you want.
Unless you have a very old system, this should not be an issue?
I'm running a 3k cpu with only 512 of ram and mine only uses around 2 to 4% most of the time.
