smithjones24
As Outlook data grows, the PST file can become oversized and more prone to corruption. Using the SysInfo PST Splitter helps prevent this by breaking the large PST into smaller, organized files. You load the PST file into the tool, and it scans the entire structure—emails, contacts, calendars, folders—so you can see what you’re working with. You then select a splitting method: by file size (like creating multiple 500 MB PSTs), by date ranges, by folders, or even by specific sender email IDs. Duplicate emails can be removed, and new PST files can be protected with a password. Finally, you choose where the resulting files should be saved, and the tool creates several smaller, safer PST files.
Read more: Split Large PST Files
